I have the following mods - ANY MODS I SHOULD GET RID OF FOR BETTER PERFORMANCE????
Old May 24, 2004 | 03:35 PM
detroit1994z28's Avatar
Hello - I have a 94 camaro z28 m6
4:10 gears
Lt4 Hot cam
Lt4 knock module
Grantenlili MAF
Pcm tuned by pcm for less
58 throttle body holley
Trick flow elbow
March pulleys
Hypertech 160 thermo
K&N air filter charger kit
1:6 roller rockers
elderbrock shorty headers
No cats
Slp loudmouth
MY car is making a loud popping sound. Like cherry bombs would make then once the popping is gone my performance kicks in. I got on the pedal pretty good and its like its missing when its making that really loud popping sound like its missing. But when It stops my performance kicks in. ANY mods above I should get rid of or add to. Another member thinks it's MY MAF sensor. I'm checking into that. But anyone have a similar problem. Before I had the hot cam and headers and cat off I had the loudmouth and once in a while it would make that popping sound. But now ever since the headers, cam, cat - tooken off - My car makes that popping sound really bad. Unless I drive it at 3k or above. Could I have damaged a piston. Because It's running bad now.
Old May 24, 2004 | 04:58 PM
Bow94z's Avatar
try puttin the cat convert. back on...maybe there isnt enough backpressure causing all the **POPPING**
Check Plugs,wires, coil, OPTI?
Old May 24, 2004 | 07:00 PM
Re
I hate to put the cat back on. What about a muffler like flowmaster. The loudmouth is just a hollow piece of pipe. I know thats the problem not enough backpressure.
Old May 24, 2004 | 08:17 PM
CamaroSS30thAnn's Avatar
yup my LM made a popping noise every once in a while.....especialy if i hit on it and let off the gass right after start up even when its warm....put ur cat on it should reduce this a little
Old May 24, 2004 | 09:15 PM
MN1996Z28SS's Avatar
Get rid of the granatelli; I had one and there P.O.S.
Apr 16, 2015 09:57 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
k1996z28
Jan 21, 2015 07:22 AM
