I have decided on my next motor....
Old Sep 4, 2005 | 06:07 AM
  #31
89385formula's Avatar
Re: I have decided on my next motor....
Originally Posted by Green95Z28
On my 68 camaro I drove around with 12.5:1 with 91 octane on the street quite regularly, I pulled the timing back the 33-34 degrees and it ran fine, it ran the times in my sig on 91 all motor, the reason I was able to do this was because it had a 268/270 degree at .050 solid flat tappet in it with a TON of overlap. (I am not saying you need that big of a cam to do it, but that is what I had and it worked for me) You might also want to consider the price of all the safety upgrades a car like yours will need, SFI dampner, SFI scatter shield, tranny blanket, when you start going that fast in the quarter you start nneding all kinds of different safety parts, and ANYTHING with an SFI tag on it costs quite a bit more than a stocker. Just something to consider. It doesn't sound like price is a huge concern so I would get ahold of a NHRA rulebook or head out to the local track and talk with a tech guy and replace anything you might NEED to before you order parts.
I am saying this next thing from personal experience... It might seem like a better idea to build the motor first, but if you do and you can't use it because every time you hit the throttle your pointed about 45 degrees off of what you should be it REALLY sucks. I mean its so lame to show up to the track with the baddest motor there and run 13s because your pouring smoke off your tires or bogging the CRAP outta your motor because you haven't done gears yet or better yet puke the guts outta the rear end on the first hit (been there done that). Its ALMOST always better to build the rear end and do the suspension and chassis work first that way when you get the motor in the car is already good to go. You might find that all your suspension, chassis and rear end work will get up there close to the price of the motor. But since you are building this motor out of necessity you don't really have a choice
Very well said.
Old Sep 4, 2005 | 08:21 AM
  #32
Kurt Crosbie's Avatar
The rear end will be done pretty much while the engine is sitting on the stand when its finished being built. The tranny will also be rebuilt before the new engine goes in.
Old Sep 4, 2005 | 08:52 AM
  #33
94zgreenmachine's Avatar
Originally Posted by Kurt Crosbie
..... good idea. Then subframes would be nice too, and...
Subframes are an absolute must, even on a stock vehicle. The lca and adj torque arm will make a big difference along with slicks.
Old Sep 4, 2005 | 12:29 PM
  #34
I have made of few decision changes after talking to Dave. He thinks I should leave the eagle 6" i-beams in there and go with a 3.5 crank instead of a 3.48. That will help with the compression and add some stroke. He also thinks I should stick with the ross 90450 pistons. For the top end he wants me to use lt4 head gaskets and mill the heads a little and deck the block. We have not calculated it yet, but this should bring me somewhere around 12 to 1 with the quench right on. I'll update later after we run the figures.
I figured I will just sacrifice the downtown for a rear end change. I am just going to pull my current motor and rebuild it with the different crank and head gaskets. This will be alot more cost efficient than building a whole new motor. Heck, those pistons cost 6-700 dollars. I'm not paying for that all over again.
By the way, my pistons are rated at 150 shot. Does this mean that I am not allowed to run over a 150 shot at all? Even with race gas?
Old Sep 4, 2005 | 01:07 PM
  #35
Jameslt1TA's Avatar
See how fast your car is when you get it together. Then worry about BIG ol' shots of n2o. It may be very had to keep that power and a 150 shot to the ground.
Old Sep 5, 2005 | 11:07 PM
  #36
I can't wait for this motor to be complete.
magman
Apr 15, 2016 03:08 AM
David Dempsey
Mar 12, 2016 12:42 AM
Bxlt1
Sep 29, 2015 03:18 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
