I have 2 warning lights on...need help locating problems
The first light is the AIRBAG light came on about a week ago and has stayed on.Any ideas why and what to do about it?
Second is my "low water" light has been coming on intermitently the past few days.The coolant level is fine.Im told the sensors dirty or corroded.Wheres the sensor located?
Re: I have 2 warning lights on...need help locating problems
the low coolant sensor is in the radiator, passenger side, below the top trans line inlet IIRC
When the air bag light is on, the system will not deploy the air bag if you are in an accident. It might be as simple as the lead connection under the dash.
You can find pics and how to replace the low coolant sensor on my Tech Page.
for the coolant sensor, its about 36 bucks, take out the battery...thats the easiest way to get to it, and get something to push it in. its easy...takes bout 10 minutes.
squarehead
Jan 15, 2015 07:02 PM
