I have 2 warning lights on...need help locating problems
Old Jul 24, 2005 | 02:24 PM
ky1967stang's Avatar
The first light is the AIRBAG light came on about a week ago and has stayed on.Any ideas why and what to do about it?
Second is my "low water" light has been coming on intermitently the past few days.The coolant level is fine.Im told the sensors dirty or corroded.Wheres the sensor located?
Old Jul 24, 2005 | 02:29 PM
Dave89IROC's Avatar
Re: I have 2 warning lights on...need help locating problems
airbag light, you need the code, could be lots, but probably the clockspring
the low coolant sensor is in the radiator, passenger side, below the top trans line inlet IIRC
Old Jul 24, 2005 | 02:41 PM
Thanks.
Is there any danger of the airbag deploying for no reason while driving?
Old Jul 24, 2005 | 02:43 PM
Dave89IROC's Avatar
unlikely, but there is a slim chance, but no higher a risk then when the light is not on
Old Jul 24, 2005 | 05:38 PM
When the air bag light is on, the system will not deploy the air bag if you are in an accident. It might be as simple as the lead connection under the dash.
You can find pics and how to replace the low coolant sensor on my Tech Page.
Old Jul 24, 2005 | 06:34 PM
phinger23's Avatar
for the coolant sensor, its about 36 bucks, take out the battery...thats the easiest way to get to it, and get something to push it in. its easy...takes bout 10 minutes.
Old Dec 14, 2005 | 02:25 PM
JD1994Z28's Avatar
Would you happen to have pics of the lead connection under the dash in your tech page.
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
siguy
Nov 27, 2014 10:07 AM
