I Got Wheel Hop!!!
I need help, what could cause it? I have Wheel Hop for all heck... from a 15mph launch or higher i have none. But if i hit it below that my back end hops like a mo fo. Please help!
You should invest in some control arms, relocation brackets and some better tires. That will solve most of your problems. I would recommend also investing in some subframe connectors but that's not going to solve your problem but does strengthen your chassis.
poly/rubber is better suited for the street. it is a bit more forgiving than the poly/poly. the rubber bushing they use is still stiffer than the stock bushings so it is an improvement. i had good results when i installed my BMR rubber/poly LCA's.
i also had good results from changing to a poly torque arm mount. they are about $15 and are well worth it unless you can afford a complete torque arm. and i had no increase in interior noise being transmitted throught he shifter like some guys claim.
hope this helps
hope this helps
Pretty much anything is an improvement over stock. The stock control arms are pressed metal and can flex quite a bit which is why you get a lot of wheel hop. With relocation brackets you have a choice or bolt-in or weld-in. For a pretty much stock car bolt-ins will be fine. I have weld-in BMR ones on my own car.
wytblur
Aug 5, 2002 02:03 PM
