I Got Wheel Hop!!!
Old Jul 7, 2003 | 10:22 PM
SilverStreak's Avatar
Exclamation I Got Wheel Hop!!!
I need help, what could cause it? I have Wheel Hop for all heck... from a 15mph launch or higher i have none. But if i hit it below that my back end hops like a mo fo. Please help!
Old Jul 7, 2003 | 10:30 PM
norcalstreet's Avatar
You should invest in some control arms, relocation brackets and some better tires. That will solve most of your problems. I would recommend also investing in some subframe connectors but that's not going to solve your problem but does strengthen your chassis.
Old Jul 8, 2003 | 02:03 AM
revtime's Avatar
I put Lakewood LCAs and Panhard rod in and it helped alot.
Old Jul 8, 2003 | 06:17 AM
teke184's Avatar
poly/rubber is better suited for the street. it is a bit more forgiving than the poly/poly. the rubber bushing they use is still stiffer than the stock bushings so it is an improvement. i had good results when i installed my BMR rubber/poly LCA's.
i also had good results from changing to a poly torque arm mount. they are about $15 and are well worth it unless you can afford a complete torque arm. and i had no increase in interior noise being transmitted throught he shifter like some guys claim.
hope this helps
Old Jul 8, 2003 | 02:41 PM
Any sugestions on which ones i should buy? OUt of the control arms and relocation bracket, i aws looking for better launchs..and no! wheel hop
Old Jul 8, 2003 | 02:57 PM
Pretty much anything is an improvement over stock. The stock control arms are pressed metal and can flex quite a bit which is why you get a lot of wheel hop. With relocation brackets you have a choice or bolt-in or weld-in. For a pretty much stock car bolt-ins will be fine. I have weld-in BMR ones on my own car.
Old Jul 8, 2003 | 03:03 PM
Red96Lt1's Avatar
Which one is better, boxed or tubular controll arm. Do they affect ground clearance any?
Old Jul 8, 2003 | 03:20 PM
No effect on ground clearance. Boxed is the stronger of the two but tubular is plenty strong already. I run boxed myself.
Old Jul 8, 2003 | 04:27 PM
TedH's Avatar
I actually cured my wheelhop by installing an airbag in the passenger side rear and adding 22 pounds of air.
Old Jul 8, 2003 | 09:21 PM
Do you mean you added air shocks? Or like an "air Bag" as in for safety?
Old Jul 9, 2003 | 07:43 AM
revtime's Avatar
Air bag in the passenger rear coil spring.
Not sure how to explain what it does but it helps the car hook up and stop wheel hop.
force10
Aug 10, 2015 08:30 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
SAR2K
Sep 1, 2002 10:49 AM
wytblur
Aug 5, 2002 02:03 PM
