I got an oil leak this car wont gimme a break!
Old Jun 17, 2006 | 11:39 PM
cridom's Avatar
Unhappy I got an oil leak this car wont gimme a break!
i found oil in the back of the intake manifold , i guess its the infamous manifold leak, and i also found oil near opti and balancer, the bar down there is also oily. help me out, if u can tell me what things i need to buy to fix this.
Old Jun 18, 2006 | 12:17 AM
Wickman's Avatar
Re: I got an oil leak this car wont gimme a break!
For less than $30.00 I got a Felpro intake manifold and timing chain cover gasket sets. The timing chain cover set also included all three of the seals in the front of the timing chain. No more oil spots in the driveway. The intake manifold kit even came with a tube of RTV.
Old Jun 18, 2006 | 10:07 AM
ChickenScreamer94's Avatar
My IM leak caused me to leak oil all over the opti and front side of the motor.
I would fix the IM leak and see what happens.
Old Jun 18, 2006 | 11:37 AM
nb 96 z's Avatar
Yeah. I would fix the intake manifold leak first. Then you will be able to tell if you have a leak near your opti and balancer. It is a lot easier to pull the intake manifold than it is to take off the front cover and replace all the seals. Good luck.
Old Jun 19, 2006 | 12:57 AM
cridom's Avatar
dud with what kind of solucion can i clean all that gunky oil??? brake cleaner?
ill do intake first , nice
Old Jun 19, 2006 | 01:11 AM
cridom's Avatar
dude if its not too much of a problem could u tell me where u got the fel pro gaskets,and the pārt number?? that would be awsome
Scottylt1
Jan 8, 2015 02:48 PM
Queens94z28
Dec 20, 2014 09:11 PM
Scottylt1
Dec 4, 2014 12:31 PM
blac94Z
Nov 28, 2014 01:53 PM
USAirman93
Nov 24, 2014 03:37 PM
