I give up... LTs SUCK
Old Nov 24, 2003 | 01:39 PM
  #46
Spinner's Avatar
Pretty basic, yo just need the tools. Unbolt the front suspension from old kmember, unbolt motor from kmembner (have it sit on a jack). Bolt new Kmember to suspension, bolt motor to new kmember. Pretty basic
Old Nov 24, 2003 | 02:18 PM
  #47
Javier97Z28's Avatar
Moderator
Re: Re: Re: I give up... LTs SUCK
Originally posted by 350 HRSS
My mechanic refuses to put any kind of headers on any 4th gen
f-body b/c of my LT's. It took him a couple of days.
They SUCK.
He's obviously not a very good mechanic. I can get them done now in a day on jackstands. A lift would cut several hours of work IMO.
Old Nov 24, 2003 | 03:13 PM
  #48
Mystic97Z's Avatar
hey spinner, i had the same problem w/ my jet hots,,,i had to cut the half tube about 1/4-1/2 in off, and it went in with a little grinding on the frame,,how bout those jet hots huh? lol
-Jason
Old Nov 24, 2003 | 05:00 PM
  #49
DarkRider's Avatar
do you think the bmr is worth it because its like $440 or should i just stick with the stock one
thanks
Old Nov 24, 2003 | 06:43 PM
  #50
Spinner's Avatar
If you have the $ go for it.
I got the DRIVERS SIDE IN! WOOOHOOO! Had to grind the lip of the kmember off completely, jack the motor to its peak, and i shoved it the fzck in there. . Slip-fot doesnt want to slip, fit and the steering linkage doesnt want to go back on. oh well. at least I got it in. its 30 degrees out, so looks like i'm gonna try to finish tomorrow
Old Nov 24, 2003 | 06:51 PM
  #51
TheHeadFL's Avatar
Same thing we had to go through. 2 hours with a hacksaw.
In all honesty, though, its the K member being adjusted differently on each car, its not Jet Hot's fault.
Old Nov 24, 2003 | 06:54 PM
  #52
Spinner's Avatar
I know . Doesnt mean i have to like it though, lol
Old Nov 24, 2003 | 08:02 PM
  #53
DrivinSidewayz's Avatar
spinner??? wtf kinda LT's do you have? i have FLP's and it took about 5 minutes to get the driver side in, all i had to do was loosen the metal loom, holding hte stock wires, just took out the back bolt and loosend the front and moved it, with a little positioning the header went right in, now on the passenger side, just the starter and alternator were taken off,.... i can see why everyone says theyre pains when you lift the motor, disconnect the steering, bang ****, grind ****...
Old Nov 24, 2003 | 08:42 PM
  #54
Spinner's Avatar
FLPs are together and relatively straight. Jet-hots.... are not . read the thread, ive said a buncha time that they're jet hot long tubes
Old Nov 24, 2003 | 09:32 PM
  #55
rskrause's Avatar
Moderator
If I didn't have all the crap I do on top of the motor (fuel lines, notrous system, water injection, etc.) I swear it might be easier to just drop the cradle and motor to change the plugs, let alone install headers. Two people, working with a lift and air tools, can drop the cradle in less than an hour after the wires, vacuum lines, fuel lines, radiator hoses, etc. are disconnected. I am not seriously suggesting it, it's just a comment on how GD hard these cars are to work on.
Rich Krause
Old Nov 24, 2003 | 10:13 PM
  #56
sorry sorry, i saw they were jet hots right after i posted... whats the point of the header not together... i dont know anything about the jet hots
Old Nov 24, 2003 | 10:26 PM
  #57
RedPhenx's Avatar
chris: if you can't get em in, you know i'll take them off of your hands
also, what did you ever end up using those rims for?
Old Nov 24, 2003 | 10:34 PM
  #58
Spinner's Avatar
The two rims with more tread I'm going to burn off as soon as I can get these finished. IE: Play tires
The other two are getting 26x11.5x16 ET Streets for the strip around Xmas
Old Nov 24, 2003 | 10:41 PM
  #59
95CamaroZ-28's Avatar
Rich Krause
Like Rich said, if you have access to a lift and air tools, drop the k-member and all to install headers. This is how we put Jet Hot LTs on a friend of mine's 95 TA. Had no problems whatsoever.
Old Nov 24, 2003 | 11:09 PM
  #60
2fbodies2NV's Avatar
Talking
All I can say is Thank God I work at an exhaust shop GO MIDAS !
