I can't believe my 02 sensor is bad??
Old Aug 11, 2003 | 03:18 PM
speed76demon's Avatar
Well part of my hesitation is a bad 02 sensor along with the opti but the 02 sensor was just replaced about 1month ago when i did my headers. Any idea what would make it go bad so quick?
Old Aug 11, 2003 | 03:24 PM
predator's Avatar
did it throw any codes just curious because i think mines are bad
Old Aug 11, 2003 | 03:27 PM
Cmr0z28's Avatar
if it is a bosch o2 sensor i wouldnt be surprised......was it an ac delco? or bosch? or other?
Old Aug 11, 2003 | 03:30 PM
How do you know its "bad"? Codes???
Old Aug 11, 2003 | 03:39 PM
it was an ac delco expensive for 2 of them and the shop checked the codes and found out
Old Aug 11, 2003 | 03:42 PM
predator's Avatar
so did the ses light come on is what i am asking
Old Aug 11, 2003 | 03:43 PM
it would come on for a min or 2 then go off
Old Aug 11, 2003 | 03:49 PM
predator's Avatar
because i am running way rich and it doesnt start acting up till it gets to operating temp so i am figuring mines are going bad
Old Aug 11, 2003 | 03:50 PM
Gripenfelter's Avatar
How do you know its the O2 sensor thats bad?
You might be burning an O2 sensor wire or your MAF might be bad and telling the PCM to dump too much fuel into the cylinder.
Old Aug 11, 2003 | 04:22 PM
yorkie's Avatar
I have bosch O2's and they work....
absolutely fine, A-OK.
Old Aug 11, 2003 | 05:34 PM
sorry the shop didnt get it from reading the codes he put his scanner on it. The passenger side 02 was fine it would fluctuate with the rpm's where as the drivers side was stuck at like 452-453 the whole time so i'm going to replace my 02 and hope this solves the rest of my problems
Old Aug 11, 2003 | 05:56 PM
NXz28's Avatar
do you have heated o2's?...4 wire or 1 wire version?...i have heard of some people having trouble with the non-heated ones after long tube install b/c they were too far away to get an accurate reading...
Old Aug 11, 2003 | 05:59 PM
i have the 4 wire
Old Aug 11, 2003 | 08:41 PM
Swtich the O2 sensors from side-to-side. If the problem follows the O2 sensor, the sensor is faulty. If the problem stays on the same side, its a wiring problem. I'd try that before dumping money into a new sensor. Being stuck at 450mV means there is no signal from the sensor... all the PCM is seeing is its own bias voltage. Could be a faulty sensor, could be a faulty wire.
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
Fatdog2
Feb 13, 2015 08:19 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
