12bolt rear end- bolt axles or c-clips?
Bolt in axles are the only way to go. If you ever break an axle, it may save you a bunch of body work!
On another note. If you are going to be running aftermarket wheels and tires, you might want to consider getting the axle for a 1982-92 F-body. It will be a little narrower, but bolts right in. The advantage is that it is lighter and allows you to run wheels with a 5" back spacing.
Good Luck.
Daren
Good Luck.
Daren
Good Luck.
Daren
Good Luck.
Daren
And definitely lose the C-clips!
Rich Krause
NHRA requires "C-clip eliminators" for cars running faster than 11.00 and any car with a spool. I'mn pretty sure Strange includes the bolted axle retainers on their base 12-bolt. Are you saying Moser charges extra for these?
Just say no to C-clips.
Originally posted by rskrause
Good advice! Moser (or Strange) will make the width you specify at no extra charge. If I'd known this when I bought mine I would've strongly considered 2" narrower. That would open up the wheel choice, at least as far as race wheels. In addition to more choices, wheels with more offset (less BS) look a lot nicer, IMHO. However, if you already have wheels you like, you would need to replace them.
Rich Krause
Rich Krause
i dont think i fully understand this. what is narrower, the housing?
Fred: when I bought my Moser they charged extra for "C-clip eliminators". Now I think they all come this way.
Rich Krause
so with a 12-bolt you cant run some of the wheels that you can with the stock one.
Rich Krause
Thanks,
this helps. Yeah, it's a $100 more from moserengineering for bolt on axles without the clips. And 100 more for 33 spline instead of standard 30spline. I went ahead and ordered the bolt on axle rearend.
I'm about to purchase a 12 bolt and hadn't considered getting it narrowed. I just purchased a set of fikse FM5's with ZR1 backspacing, and they stick out a bit. How narrow should I go? 1" might fix it, and I'm pretty sure 2" would be to much. I don't want to overshoot here. Thanks
Malcolm
Malcolm
Malcolm
Malcolm
Fikse wheels
Rich Krause
Currently the wheels have 335's on them (I plan to run 315's) and they do rub a bit. I thought that a 17x11 with the grand sport offset would fit wich I believe is 7 3/4" compared to 7" for the ZR1 (not positive). If by clearanceing you mean hammering I wouldnt be offended. If it gets more complicated I'm not sure, I just don't want them sticking out if it's avoidable.
Malcolm
Malcolm
"GS" offset is 50mm, with a 7.93" backspace. The ZR1 offset is 36 to 37.5mm (varies with some aftermarket models), making the backspace about 1/2" less or 7.40-7.43".
The main problem with backspace availability is trying to run 15x10's. The nice ones like the ConvoPros (and many others) aren't available in anything more the 5" BS. So you get stuck with AutoDrags, Pro-Stars, Draglites, or $350/wheel Bogarts.
