I blew the ignition sensor and car died. . HELP!
Old Jul 1, 2009 | 08:48 PM
customlt1's Avatar
So im cruising around earlier today, car is running perfect and then BAM car dies. After trying to start it several times i started taking a look under the hood. I notice that the ignition sensor blew. I replaced it and it fired right up. No problems on the drive home. So my question is why or how would that fuse blow?
Also my car a 1997 trans am full exhaust, cam, 1.6 RR, and some other mods. All mods installed at least 3 years ago.
Old Jul 1, 2009 | 08:53 PM
green96ta's Avatar
hmm
it could be a bare spot in a wire that just happend to short out for a sec. thats happened to me.
Old Jul 1, 2009 | 10:23 PM
What is the "ignition sensor"? Do you mean the IC Module?
Old Jul 2, 2009 | 09:41 AM
customlt1's Avatar
My bad, i meant IGNITION FUSE
Old Jul 2, 2009 | 04:41 PM
Look at the fuse diagrams and listing in your Owner's Manual. That will show you what components are on each fuse. Then you can systematically check each load on the fuse to see which one is causing the problem. If you don't have an Owner's Manual, Shoebox has a link to online manuals:
http://shbox.com/pdf/manuals.html
Queens94z28
Dec 20, 2014 09:11 PM
Ari G
Dec 11, 2014 03:21 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
