B+ ?? cannot scan OBD II ses
Old Jun 30, 2009 | 04:07 PM
blackcars's Avatar
Hey guys i've got a question, i've got a 96 z28 i'm helping somone with and going behind someone else's work. (ugh) basically helped install the engine and got the car running but i go to scan it and it won't for the ses. I've checked all the fueses on the interior and the block under the hood and all the fuses are good. nothing popped. Someone mentioned to me a B+ circuit might be the problem but i've never had to deal with that. Anyone know where that is in the system? I've looked at a few places online and may have to resort to buying gm manuals or something to track it down. I looked at shboxs' site and didn't see it or i missed it. I usually don't post questions cause i usually research here and a few other sites for info but for this i'm coming up blank! I've worked on lt1's for a while and have not stumbled across this problem before. Thanks for any info!
Old Jun 30, 2009 | 04:26 PM
The only thing about power for scanning would be pin 16 of the DLC. It should have 12v on it and is powered by the lighter fuse.
Old Jun 30, 2009 | 04:50 PM
blackcars's Avatar
I'll check that out. I was assuming it was the same power supply for the lighter. The fuse isin't blown but that could mean its not getting power also. Maybe a wire or something is cut or loose. Just have to go behind work and see what the deal is.
Old Jun 30, 2009 | 04:57 PM
blackcars's Avatar
hey is that the bottm pin on the far left or right? i can't remember....i'll have to look that up. Glad that isin't a jepordy question
Old Jun 30, 2009 | 06:22 PM
Bottom right pin. Check it with a meter.
Old Jun 30, 2009 | 08:43 PM
blackcars's Avatar
is it constant on i assume?
Old Jun 30, 2009 | 09:35 PM
Since it is powered by the lighter fuse, yes. Of course, you can't scan a car unless the ignition is on (doesn't have to be started).
Old Jul 1, 2009 | 03:47 PM
blackcars's Avatar
with a tester i'm getting a good light so it has power there. Where else should i look? or is there a schematic i can look at?
Old Jul 1, 2009 | 03:58 PM
moparman's Avatar
What kind of scan tool do you have?
Old Jul 1, 2009 | 04:28 PM
If you have power at the pin, there is no problem there (with power).
Old Jul 1, 2009 | 05:20 PM
blackcars's Avatar
I used a snap on scanner and it didn't work, don't know the model # and then ran it up to autozone and tried theirs and both said "error cannot read engine" or something to that effect. So i'm just wondering if its a wire or a ground somewhere that i'm not thinking of. It blows my mind to see power cause i can't think of what else would prevent a scanner from reading the engine. i may just have to buy a GM manual for the car and start chasing wires.
Old Jul 2, 2009 | 05:28 AM
Guest47904's Avatar
Guest
It does take more than just having power at the DLC to scan it.
Old Jul 2, 2009 | 07:32 AM
http://shbox.com/1/1996_ec_02_DLC.jpg
Old Jul 2, 2009 | 06:32 PM
blackcars's Avatar
Sweet! thanks guys i appreciate the posts! This will give me a great map to follow to see whats going on. I'll see what i can find on sunday and post what i find on here. I always like learning something new and this will definitely be new to learn!
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
greenzee28
Sep 25, 2015 04:29 PM
tommalcolm
Sep 11, 2015 03:39 PM
