hydrolocking??
Old Aug 1, 2003 | 08:17 AM
Bobbys_97_Z28's Avatar
hydrolocking??
im going to use sea foam and put it in the tb to have it sucked in there....well i heard in the earlier post that you can hydrolock it? is this something i should be afraid of?i m ean im not dumping the whole can in there to stall it...just like a 1/4 of it.....im going to use the whole can...but wheni stall it out im gonna just use the last 1/4 of it.....what will this hurt? o2's and plugs? cuz i just changed all the plugs
Old Aug 1, 2003 | 08:27 AM
TransAmGT's Avatar
Yes, you will have to change the plugs after you do a seafoam. If you have old plugs I would put those in to save yourself from having to put new plugs in again!
Old Aug 1, 2003 | 08:46 AM
ok
im gonna drop my y pipe to do the plugs i guess then...and when i do sea foam should i just leave it open headers?instead of bolting it back up and having to change the plugs again?
Old Aug 1, 2003 | 09:48 AM
TransAmGT's Avatar
You can, it wont hurt anything. Just make sure you let them baby's cool off good before putting the new plugs back in. Also to make sure you got everything out of the motor you can turn the key while the plugs are out and if there is anything left in there it will come out of the spark plug holes, I'm not sure it you have to change your oil afterwards either but I would just in case. I haven't ever used seafoam. But I did hydrolock my car last year and these are the things I did to make sure I got all of the water out of the cylinders. This should apply similar to what you are doing. Good luck!!
Old Aug 1, 2003 | 10:22 AM
scoobysnax83's Avatar
Wow, Nelly......stop where you are and do a search. It is not necessary to change plugs afterwards. If anything you should be more worried about the O2's. Just do a search and you will have an overabundance of information.
Old Aug 1, 2003 | 10:23 AM
i did...nothing really explains everything and everyone also has different opions..even though thats bascially waht im asking everyone right now...but what if i take the o2's out? and do all this? that would be good right??
Old Aug 1, 2003 | 10:56 AM
http://web.camaross.com/forums/showt...hreadid=150118
There ya go, that should get you started. Let me put it this way, if you want to change out your plugs and O2's this is the time. Go ahead and seafoam and then proceed to change them. Since you are removing the O2's (good idea) then they should be good. But if you have a HIGH mileage LT1 then I would suggest replacing them as soon as you can. You'll notice a world of difference if they are old. You can do it with the Y-pipe removed but let it be known that it will FOG like no other. All that will probably end up in your cabin, so be ready. All in all, I wouldn't worry at all about the hydrolocking. I've done it every 10,000 miles or so since new. I'm at 163,000 miles with no engine troubles whatsoever. Good Luck !
jasonduaine
Mar 7, 2015 09:44 AM
ablkbrd
Mar 24, 2013 11:58 PM
Detroit808
Dec 2, 2004 08:45 PM
4thgen3121
Jul 20, 2004 12:01 PM
b-stevens
Oct 18, 2003 03:25 PM
