HP with hotcam
Old Dec 28, 2004 | 08:43 AM
  #31
GREGG 97Z's Avatar
Re: HP with hotcam
355/350
Originally Posted by RobsWS6
Have to correct you on that one. The HOT cam doesn't loose any low end. Dyno numbers from stock to after the HOT cam went in were pretty much identical to 2500, then the HOT cam started spreading the gap. There is no low speed driveablilty problems with the HOT cam as its really a mild cam.
I don't know about you but I sure lost some low end torque after adding the hotcam. But I also have single cat shorty headers/y pipe and an ORP (no cat). I think that lack of backpressure adds a lot to the off idle torque loss. With the stock cam/manifolds the car used to pull out in first gear without any throttle, it definitely wont do that now. Mine is much more challenging to drive in bumper to bumper traffic than it used to be, even if for a small cam. The midrange to top end pull now more than makes up for that little issue though
Old Dec 28, 2004 | 10:03 AM
  #32
T/A lt1's Avatar
Re: HP with hotcam
I really liked my Hotcam when it was in my T/A. I went from running stock 13.80's@100mph to 12.50's@108mph with stock 3.23's. My mods were Hotcam kit, AS&M headers, 2800 Vigilante, CSI W/P and a tune from a fellow memeber from here. I spent a little over $1,000 and p/u almost 1.5 seconds! I eventually palyed with the tune and swapped to 3.42's and ran 12.31@110mph before I changed setups. Thats the bad part about dragracing it's never fast enough! Later Clint
Old Dec 28, 2004 | 10:30 AM
  #33
Antz97ZNJ's Avatar
Re: HP with hotcam
Any chance i will be able to give an LS1 a run
You can probably take one til 80-90 but after that dont count on it...01-02 6spd generally run in the 107-109 mph range...LT1 needs alot to put out those numbers
HarleyZ28
Oct 5, 2015 06:23 AM
MDZ28
11
Sep 24, 2015 09:15 AM
k1996z28
Apr 13, 2015 06:54 PM
WildRidez
Jan 16, 2015 03:10 PM
stngh8r
West South Central
Oct 22, 2002 03:44 PM
