hows my dyno sheet look...
Old Feb 6, 2004 | 03:19 PM
Seal's Avatar
yeah I know i'm running rich as hell lol...
imma talk to Ion, and see what we can do, cuz from the last tune, i went richer when i should have gone leaner
anyways here it is....
266rwhp/304rwtq AFR: 10.1 =-O=-O=-O
mods:
Both cats taken out
Ion tuning
KN intake
Bosch cheap plugs
Cutout
160 thermo
automatic btw
www.fbodyv6.com/Emir/dyno04.jpg
I guess with bringing the AFR to about 13 i'll be around 280rwhp and 320rwtq
Old Feb 6, 2004 | 03:28 PM
ibanez6rg's Avatar
You live in Davie, Florida? There was a high school prank show on MTV the other day with one of the locations being Davie.
Old Feb 6, 2004 | 03:30 PM
Seal's Avatar
THREAD HIJACKER!!!
no, but i'm very close (about 20 mins)
Old Feb 6, 2004 | 03:58 PM
kgkern01's Avatar
Those numbers look about right for the few mods u have. I doubt that you will gain 14HP and 16 ft/lb of TQ from leaning it up, but you never know. Those are about the same numbers that I made with no tune and 15:1-15.8:1 A/F ratio above 3000 RPM.
Old Feb 6, 2004 | 04:14 PM
madwolf's Avatar
Emir,
there has to be something wrong with the dyno. I definetely leaned it out the AFR and it has to be right around 13 right now, considering your gains....
Nice numbers!
Old Feb 6, 2004 | 04:17 PM
ibanez6rg's Avatar
[threadjack-again]
Ion's back! Woot! I'll need to contact you soon about some work.
[/threadjack-again]
Old Feb 6, 2004 | 04:20 PM
Seal's Avatar
Originally posted by madwolf
Emir,
Nice numbers!
very odd...
if i had more $$$ i'd get it dynoed at a more reputable place... :P
there was a jetta before me, and he seemed to get the AFR right
Old Feb 6, 2004 | 04:25 PM
speed_demon24's Avatar
Originally posted by Seal
very odd...
I'm just guessing, but if you had the cutout open and they had the a/f tube up the tail pipe, can that make the a/f read incorrect? Oh, and I would go to kelly chevrolet, they gave me a dyno sheet of 100rpm incriments of hp/torque and a/f, which tells you exactly where your a/f is.
Old Feb 6, 2004 | 04:27 PM
You could probably gain 15HP by richening it up to 13.0:1, just as he will easilly pick up that kind of gain. Just leaning out the stock programming 11.7:1 target A/F ratio is worth 15HP. Going from 10:1->13.0:1 should produce even more gain. Why would you even dyno it a 15.8:1? Could do serious damage. Is it possible they put the wide-band after the cats
Seal:
I'd also be concerned by those dips between 5,100-5,200rpm.
Old Feb 6, 2004 | 06:30 PM
kgkern01's Avatar
Injuneer, before I dynoed the car, I had no idea that I was running lean. It goes from 12.85:1 AF @ 3000 RPM steadily climbing up to about 15.6:1 @ 4600 RPM and spiking up and down there after in .1:1 increments. The wideband was put in the cutout. There were many other f-bodies being dynoed at the same time also.
Here are the Dyno Files, which can be viewed with DynoJet RunViewer
Run 1 (cold engine cutout closed)
Run 2 (engine warmer, cutout still closed)
Run 3 (cutout opened wideband placed in cutout)
Run 4 (same day, new fuel filter, cold engine, cutout still open)
Set the smoothing bar at the top of the RunViewer to 0 to see the dips in the charts.
Don't mean to hijack
poloz28
Sep 9, 2002 10:09 PM
Lions3
Aug 30, 2002 01:03 PM
CamaroZBoy
Aug 19, 2002 12:41 PM
CLEAR
Aug 16, 2002 02:35 AM
LumpyCamZ28
Aug 13, 2002 09:16 AM
