How to use seafoam??? Should I get some???
Old Feb 26, 2006 | 04:43 PM
IrocManiac's Avatar
Hey guys I've been reading lots on here about seafoam seems to be a pretty good 10 dollar or less investment. But I have not found anything that clearly states how you apply it. Do I run it in the gas tank? Is there a way to put it in the intake manifold? How does it work what should I use? I'm not having any problems with my car but I've read so much good stuff about seafoam I can't help but think it might make my car run even better especially since I dont drive it hard enough to knock carbon off the pistons etc...
Thoughts on this?
Old Feb 26, 2006 | 05:07 PM
amean94ta's Avatar
Re: How to use seafoam??? Should I get some???
hook hose to the intake via brake booster hose and let idle any monro muffler can do it for you but they charge like $75 its called a 3 step there
Old Feb 26, 2006 | 05:09 PM
LT1 POWR's Avatar
You can put it into your fuel lines through your gas tank, crankcase through your oil filler tube, and into your intake manifold through the brake booster line. I bought mine at NAPA and it has directions on the bottle. Here is a nice how to write up.
http://www.fbody.com/tech/details.cgi?id=60
StephenDeli22's Avatar
Ive never used it but this link tells how.
Old Feb 26, 2006 | 05:31 PM
IrocManiac's Avatar
Hard on spark plugs and O2 sensors...hmmm that kinda sucks a lot
Old Feb 26, 2006 | 07:36 PM
1racerdude's Avatar
Don't use it,there is nothing to gain and a bunch of dollars to loose
If ya DO use it,add two cans of compression while ya are in there.
Old Feb 26, 2006 | 08:30 PM
Evil Eric's Avatar
I just bought it in an aresol can and held the TB open and sprayed the intake full, easy to make sure you get in every cylinder that way.
Old Feb 26, 2006 | 08:52 PM
turbo_Z's Avatar
Haha exactly. All it does is produce a white cloud of smoke.
Old Feb 26, 2006 | 09:55 PM
HardcoreRM125's Avatar
It makes a Quad 4 engine smell bad/smoke horrendously. It did have noticabley better idle quality for a few weeks though.
Really your best bet is to run a quality fuel injector cleaner consistently through the system
I use Lucas. Its expensive, but works well.
Every other tankful, I put some in. Not the whole bottle, SOME lol.
FWIW: When I got my car, it was totalled and sat for 8 years without running with fuel in the system. All 8 injectors were totally clogged. I soaked them in really strong carb cleaner for a few hours, put them in and they sprayed nice cones. Using injector cleaner frequently, they still produce a perfect very fine cone of fuel. It also says that the Lucas stuff cleans pistons/heads/valves etc. and lubricates the cylinder walls, so you dont have to worry about it taking the oil off the cylinder walls and causing wear because of it.
marlar98
Sep 19, 2015 07:53 AM
Anon
Jul 23, 2015 12:18 PM
94GrayV6
Nov 20, 2003 11:22 AM
Marky82
V6 Tech
Apr 13, 2003 02:16 PM
bad1LEz
Mar 30, 2003 04:48 PM
