How to tell for sure if fuel pump is dead?
Old Jan 23, 2004 | 03:56 PM
Black94mula's Avatar
My buddies T/A won't start and i'm thinking its the fuel pump. I had him push the schrader valve and he said nothing came out. Is there another way to check, maybe disconnecting the filter or something?
Old Jan 23, 2004 | 04:04 PM
There is a grey "test connector" near the PCM that allows you to run the fuel pump to test it. If it isn't running, could be a relay problem. In any case, if it does run, you need to check the pressure with a pressure gauge attached to the Schrader valve.
Shoebox's tech pages have info on the test connection and the relay.
http://shbox.com/1/4th_gen_tech1.html
Old Jan 23, 2004 | 04:20 PM
Cool, thanks. So if I run 12volts to that connector and the fuel pump runs, that means.....relay problem?
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
ro2207
Dec 4, 2014 06:18 PM
