how to reset the service engine soon light
Old May 24, 2008 | 10:38 PM
remy2435's Avatar
can anyone tell me how to do so. i dont have a reader so thats out of the questions. Thanks for any help.
Old May 24, 2008 | 10:40 PM
ACE1252's Avatar
Pull the PCM fuse for 10 minutes. That will reset it.
Old May 24, 2008 | 10:45 PM
brianswimmer23's Avatar
just what ace 1252 said, you can also disconnect the battery!
Old May 24, 2008 | 11:03 PM
It's the PCM BAT fuse. 30 seconds will do fine.
Old May 25, 2008 | 10:01 AM
If the light is on, there is an active problem that needs to be fixed. If the problem goes away, the SES light will go out, and the code that turned the light on will remain stored in the PCM for quite a while. You can clear the light as Shoebox indicated, but if the system still has the problem that turned the light on in the first place, it will eventually come back. Turning the light out doesn't "fix" anything. It just loses the stored code.
Have you scanned it for codes? Many auto parts store will do OBD-II for free, or you can get a code scanner for less than $50 from Harbor Freight.
bfmv13trivium
Jan 14, 2015 09:57 AM
97z28k&N
Jan 9, 2015 04:58 AM
Injuneer
Dec 15, 2014 09:36 AM
CaRParts102
Dec 6, 2014 08:45 AM
mspennyhughes
Nov 28, 2014 03:22 PM
