How to remove my PCM?
Should take about 5 minutes. I think you need an 8mm socket, or is it a screw driver? Can't remember. But, there's two bolts on the case. Remove them....pull the PCM out. Unplug the four main plugs. Now reverse the procedure and just plug everything back in; its color-coded for easy install too!
Originally posted by Rodrigues
Its a 10mm socket... You will also need a regular screwdriver to lift the lip on the connections because its hard to with your hands...
I use a flathead, I'm not busting my my pretty nails just to get a PCM off
Facing the engine compartment its on the back left, aluminum box, with a peice of black plastic holding it down, which in turn is held down by 2 bolts.
Victor Lamb
Aug 26, 2017 02:52 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
