How to remove the crank timing gear?
Old Nov 9, 2003 | 06:48 PM
madwolf's Avatar
Arrow How to remove the crank timing gear?
I know there's a special tool for pulling the crank timing gear, but how would I do it if I don't have that tool? Does autozone or any other parts store carry something that would work?
How about reinstalling it?
Thanks.
Old Nov 9, 2003 | 07:14 PM
LPE Z convt's Avatar
Any parts store like autozone will have it. It looks like a puller for a steering wheel (3 prongs that wrap around the gear and pulls from the back).. The gear will come off alot easier than the crank hub did.... Use a threaded rod in the crank snout and a big socket to( push against the gear) or pipe fitting ,washers and a nut to reinstall it don't just hammer it on...
Old Nov 9, 2003 | 07:51 PM
It will come off pretty easy with a 2 or 3 jaw puller. It also installs easier than the hub does.
Old Nov 9, 2003 | 07:56 PM
madwolf's Avatar
Thanks for the help guys.
I just started tearing the engine appart and was happy that my hub was very easy to take off. That's the good part.
The bad part:
broken IAC valve connector.
broken IAC valve
broke off a piece of timing cover on one of the dowel pins
ripped the pan gasket even though I unbolted the oil pan
The funny part is that it's not the first or second time I'm doing this...
HectorM52
Jul 30, 2017 11:46 AM
97SSdude
Dec 31, 2014 07:43 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
1LEThumper
Jul 14, 2003 12:45 PM
