How reliable would this setup be for a daily driver?
Old May 30, 2004 | 09:53 AM
Erik 94TransAm's Avatar
Looking at buying another 94 TransAm, but need to know how reliable this would be for a daily driver. Would this need constant repairs/work or pretty much as good as a normal F-bod?
These are the mods the car has:
383 ci, LT-1, procharger supercharger, stage l heads, 9.2:1 comp, 500+hp,Forged internals, built tranny, 28 injectors, 8 psi, full exhaust, 510/510 cam.
The car has 38k miles on it, not sure how many with these mods.
Any help is appreciated
Erik
Edit: The price he's asking is $9,000-seem like a good deal? Its black w/black leather and t-tops
Old May 30, 2004 | 10:46 AM
Camaro_Maniac63's Avatar
If the engine has been built and tuned properly, it should be a reliable car. I would look into who short block was built by, and how the car was used. $9000 for a car like that, if it is good condition, is a very good price IMO. Good luck.
Old May 30, 2004 | 12:04 PM
Thanks for the help-any other input?
Old May 30, 2004 | 12:21 PM
med_reject's Avatar
those injectors are way too small. How much boost is the supercharger running?
Old May 30, 2004 | 12:42 PM
He said he's running 8lbs of boost
Old May 30, 2004 | 05:53 PM
med_reject's Avatar
the setup itself is very reliable. If its done without care to detail, you can get a lot of headaches. Eg, if old gaskets are reused, or care is not taken to make sure everything is sealed when put back together, you can get leaks. Revving a lot on a stock timing chain and sprocket is also not good for it.
In short, the setup looks good on paper. My big concern is the injectors, it wont be hard to max them out with your setup, and worst case sceanario would be to lean out on high rpm and detonate. Obvisouly not a problem for daily driving.
Old May 30, 2004 | 06:05 PM
Injector size may not be an issue.... depends how it adds the extra fuel. If it has an FMU to raise the fuel pressure proportional to boost, those injectors may be OK. Wouldn't hurt to check them with a dyno pull with a wide-band.
Old May 30, 2004 | 07:24 PM
gb95zconv's Avatar
IMO....power adder cars dont make good daily drivers.....if you cant afford down time due to breakage stay NA or get you a beater to drive and save TA for special occasions
Old May 30, 2004 | 07:35 PM
Eliminator's Avatar
seems a little much for a daily driver.
timmy39120
May 8, 2015 11:41 AM
alex5366
Feb 17, 2015 08:12 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
cmdeshon
Dec 12, 2014 10:51 PM
Snoman73
Nov 17, 2014 07:22 PM
