How to read the dipstick?
Old Apr 7, 2007 | 11:20 AM
micfly83's Avatar
How do you read the dipstick?
I just bought some engine restore stuff, due to my engine puffing out some smoke on startups and burning some oil, and I dont want to overfill it.
It seems like there are some holes in the shaded area on the dipstick and i'm wondering if this could indicate .5 qt marks
Right now the level is about half way up in the shaded area.
I'm gonna drain a little oil and then add it in as I'm about 2,000 miles away from my next oil change.
Dave89IROC's Avatar
not sure on the holes, but the shaded area is 1 qt.
Old Apr 7, 2007 | 11:24 AM
Then it is about a half quart from being full.
Old Apr 7, 2007 | 12:32 PM
micfly83's Avatar
Gotcha
I'll guess I'll try to get rid of about 3/4-1 qts
I haven't opened the can of Engine Restore, but I'm assuming its thick enough and has a color on it so I can see it on the dipstick before its had a chance to mix with the oil.
Old Apr 7, 2007 | 12:36 PM
mdacton's Avatar
I used to have to do similar stuff at a shop.....boss didn't want to waste the new oil...
I just drained it in a clean container then added it back and checked it to make sure it was right.
trying to drain just a little of it out is going to make a big mess
Old Apr 7, 2007 | 12:43 PM
tony_mid's Avatar
Just FWI it is better to run ur engine a little low on oil than have too much oil.
Old Apr 7, 2007 | 12:45 PM
micfly83's Avatar
Yea I might just do that
I might be wrong but I thought if you unscrew the drain plug very very slowly it will start to come out a little bit, and then i'd just chill until enough was gone and tighten it back up.
I can't think of anything that I can catch it in that I'd be able to put it back in easily
As of now I was planning on using a gallon milk carton that I cut in half.
Old Apr 7, 2007 | 12:49 PM
mdacton's Avatar
get a gallon milk jug and put a funnel in the top....
Old Apr 7, 2007 | 12:50 PM
micfly83's Avatar
I thought my car held 5qts though?
and theres only 4qts in a gallon...there might be some spillage
Old Apr 7, 2007 | 01:04 PM
mdacton's Avatar
if its been started then the filter is full too.....shouldn't spill too much
Old Apr 7, 2007 | 05:25 PM
mattbailey's Avatar
I wouldn't use that stuff if I were you. If it's smoking, the damage is done. Your not going to help the seals or rings by running that stuff....
Old Apr 7, 2007 | 07:42 PM
micfly83's Avatar
Its already been done..
And all the reviews are very positive on it
Old Apr 7, 2007 | 08:05 PM
mattbailey's Avatar
One of my close friends tried it, he sold his car about 6 months later due to oil consumption... Good luck
Old Apr 7, 2007 | 08:19 PM
micfly83's Avatar
This is a step to fixing it
From what I hear it may not help, but it wont make anything worse
Old Apr 7, 2007 | 08:54 PM
mattbailey's Avatar
I will say that there was some nasty looking stuff that came out of his oil, but it didn't help his issues, maybe made them worse.
HectorM52
Jul 30, 2017 11:46 AM
jmadoll
May 27, 2015 07:13 PM
jmadoll
Mar 3, 2015 10:16 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
