How much is too much resistence in plug wires?
Old Apr 4, 2004 | 01:08 PM
Red_94Formula's Avatar
I used my multimeter on my MSD and Taylor wires. I saw a huge differnce between the two. All 8 MSDs have between 35 to 45 ohms resistence when the Taylors are all between .9 and 1.1 ohms.
I went a little deeper and took apart the MSDs and noticed all of them had rips in the wires(underneith the rubber coating). This is caused by bending the wires 90 degrees. once that happend the wire snaps inside. They are very rigid and unflexable wires which makes them very fragile. The Taylors can be easily bent with out the wire spliting inside. I say stay away from using MSD wires and if one is using them check them for resistence.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
