How much RWHP will a 7.5 take??
Old Oct 14, 2003 | 12:37 AM
stockLT1's Avatar
Anyone know a round about figure on how much RWHP a GM 7.5 rear end will take??
Thanks!!
Old Oct 14, 2003 | 12:50 AM
Aeromaks's Avatar
about 40 passes on drag radials with mods below. =)
talking from experience. lol
Old Oct 14, 2003 | 01:31 AM
Z95m6's Avatar
5 or 10 less rwhp than what we have stock.
Old Oct 14, 2003 | 03:27 AM
QCKZ28's Avatar
Z95m6 i agree with you, nice triple post btw.
if you put a set of et streets on an m6 it and launch it hard, you will break the rearend quickly even on a bone stock motor 250rwhp
hp doesnt break rearends, traction does.
i have read about ppl breaking it with stock M6 and drag radials on the street.
jesse
Old Oct 14, 2003 | 05:40 AM
funina91ss's Avatar
I love my 10 bolt 1.601 60ft times and still pullin the wheel But I dont think it will last forever There are a few A4 guys running Low 1.6 and mid 1.5's on the 10 bolt. You 6 speed guys are out of luck
IMO I dont think traction is what really breaks the rearend I think it is more the the shock it gets if you have a M6 from the slack. Reason I think this is my 91 Camaro RS 305 TBI went threw them like nothing (spec stage 3) A hard hitting clutch will kill a rearend real quick.
Maybe one day the 12bolt will come out to the camaro and go into my TA
Old Oct 14, 2003 | 06:15 AM
Raptor1's Avatar
Ditto! A4's are a LOT easier on the drive train than a manual. I had 600+ passes on my 10 bolt with 4.10's and my combo before the ring gear broke. I know guys putting down 400-450 RWHP and pulling 1.5-1.6 60's and not breaking the 10 bolt. BUT they're all automatics
Old Oct 14, 2003 | 08:28 AM
Grease's Avatar
I'm pretty sure you can put over 1000hp through a 10-bolt rear end. Just make sure its from a 60mph roll with street tires.
With 327rwhp, I made over 200 passes last year with 4.10s and drag radials in an M6, mostly with 1.8x 60fts. Never had any trouble. then I was doing donut one day in a parking lot with street tires and broke my pinion gears.
Now with 412rwhp, I've made about 50 passes with 4.11s with alot of 1.8 60fts. No problem so far.
Old Oct 14, 2003 | 09:04 AM
jomo_eng's Avatar
I know Mike Hoffpauir ran:
Best E.T. 10.98@121.44_ 1.45 60'_ 12/6/02
________________ Race Weight 3300lbs
This is with untouched heads N/A A4. Although this is an LS1. Not sure on power because mikes car was never dyno tuned.
Later,
JoMo
Old Oct 14, 2003 | 09:16 AM
LeftoverChinese's Avatar
Its a crap shoot man. Some people can make it into the 10's and some people break them with a stock car.
Will you break your 10 bolt?
*shakes mighty eight ball*
My sources say yes!
Old Oct 14, 2003 | 12:36 PM
Z95m6's Avatar
sorry about the triple post but i meant it. Its also a good way to get the post count up. If you wouldn't of mentioned any thing i would have 2 extra posts right now.
Old Oct 14, 2003 | 01:21 PM
T/A lt1's Avatar
knock on wood. I have been dragging my T/A for over 3yes. and never broke the rear yet. I dynoed 450rwhp and 500ftlbs. on a 150shot of N2o and have pulled 1.5 60's with the driver tire almost a foot off the ground with 0 problems. The only thing that ever happened is the posi peglegged after 140k miles so I put in a $100 SLP unit and it's still kickin. I am going to build a Ford 8.8 rear for when this one decides to crap out and I want to put over 500rwhp thru it. These are my own experiences. Autos rule
Old Oct 14, 2003 | 05:55 PM
stockLT1's Avatar
Thanks for the replys guys...
I used to have a 383 on a 225 shot and never broke a rear end....
But, I never really had a good clutch either tough...
Now I have a 12:1 355 on a 200 shot with a spec stage 3 carbon, and I broke the rear end on the 2nd pass.....I didn't even launch hard, I was on the street, not even at the track.
Of course I am running ET Streets. Maybe DR's is the way to go....
What do you guys think?
Old Oct 14, 2003 | 06:02 PM
funina91ss's Avatar
Moser has what you need or put in a stock clutch! its not really the power that breaks it! Its that "SPEC STAGE III" As said before I broke 3 10bolts with my 305 tbi 260 flywheel hp!
Old Oct 14, 2003 | 06:14 PM
blazzinbird's Avatar
i broke mine real fast lol
sticky tires and a high gear equells no good
Old Oct 14, 2003 | 06:19 PM
Derrick Redd's Avatar
Best of 1.55 60ft. with numerous low 1.6's. Times below with 3650 raceweight.
