how much power am I giving up?
Old Oct 14, 2005 | 04:33 PM
97HUGGER's Avatar
I am rebuilding my motor and going with a 383 and I am just wondering about re-using my lightweight flywheel or my heavier stock flywheel - the difference in weight is 7 lbs - is that going to make any power difference or is it just going to be a difference in the way the car revs up? I was thinking of going back to the stocker for driveability at lower speed. Thanks.
Old Oct 14, 2005 | 05:13 PM
Re: how much power am I giving up?
A heavier flywheel shows up as less power to the rear wheels on a dyno, since the engine has to use part of its power to bring the rotating mass up to speed. But in a drag race application, when you rev the engine at the line, the heavier flywheel stores more energy so more power is available for the launch.
Old Oct 14, 2005 | 05:40 PM
Kurt Crosbie's Avatar
What other things on a car store more energy even though they show up as power losses on a dyno?
Old Oct 15, 2005 | 02:29 PM
Anything that can be rotated to high speed before your launch. Pretty much stops at the flexplate/torque converter on an automatic, and the flywheel/clutch on a manual.
Anything that is at rest - tranny rotating elements, driveshaft, differential, rear axles, brake rotors, wheels and tires - will absorb the energy needed to accelerate it from rest to its maximum RPM, reducing the power available at the contact patch.
Keenan
Jan 19, 2023 12:24 PM
cobrakilling101
14
Mar 17, 2015 10:42 AM
siguy
Nov 27, 2014 10:07 AM
XtremeLt1
Sep 13, 2002 08:50 PM
