Converting to OBDII due to high stahl problems?
Old Oct 14, 2005 | 07:00 PM
94 TEALBIRD's Avatar
Anyone ever hear of this? I'm putting a 3200 Vigilante in my '94 Camaro, will I need to do this?
Old Oct 14, 2005 | 07:33 PM
96capricemgr's Avatar
Re: Converting to OBDII due to high stahl problems?
Heard of it but at least seeing IF you have the problem first is a good idea asd is trying programming fixes in the pcm you already have. Updates/tuning/ logging are all more expensive for OBD2 much more expensive.
Old Oct 14, 2005 | 07:42 PM
MEAN LT1's Avatar
I had that problem on my camaro and switched to a M6. Best mod ove done tot he car since.
Old Oct 14, 2005 | 08:20 PM
Some have found fixes for the high stall problems with OBD-I. Check the computer/diagnostics forum.
Old Oct 14, 2005 | 08:22 PM
Okay thanks for the advice everyone.
Old Oct 14, 2005 | 10:10 PM
95WhiteTA's Avatar
what kind of problems do people have? My car acts a little wierd sometimes since the 3200 stall, so i wonder if that's why or if it's just a coincidence.
Old Oct 15, 2005 | 08:56 AM
chrism400's Avatar
I have 2 PCM' s and both have no trouble with high stall after the fix from Madz. Don't change over - just get the fix.
Old Oct 15, 2005 | 09:02 AM
The issue we are talking about is that sometimes if the car hooks well it will confuse the pcm and go into a limp mode and not shift till you let off the throttle.
A high stall even without that issue can benifit from reprogramming to correect the surging and idle weirdness they can cause.
Old Oct 15, 2005 | 11:31 AM
95WhiteTA's Avatar
yeah, my car's doing that, i have a pcmforless tune so hopefully bryan can help me out. I dont want to have to buy a madz tune just to fix it.
Old Oct 15, 2005 | 11:34 AM
Honda Hunter's Avatar
Bryan can do the fix also.
Old Oct 15, 2005 | 02:41 PM
chrism400's Avatar
I have some of Bryan's programs and they work just fine too.
Old Oct 15, 2005 | 02:53 PM
I never had a chance to try mine before we started the 383 project. Is there any performance loss for people high stall fix done through the computer? For some reason after looking over the fix I have a funny feeling there has to be some performance loss.
PCLZ28
Dec 24, 2015 05:19 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
ChrisFrez
Feb 15, 2015 07:49 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Cam's maro
Dec 28, 2014 09:30 AM
