How much more Compression with 64cc to 54cc?
Old Feb 14, 2007 | 12:07 AM
  #16
tnmotown's Avatar
ok guys help me out, I have the JE pistons catalog and in the back it has the CR calculator. Here are my number that im putting in and im getting around 11.5:1 CR. Are these numbers right?
CR= Swept Vol. + TDC Vol. / TDC Vol.
Swept Volume = 3.1416 x Bore(4.030) x Bore(4.030) x Stroke(3.75) / 4 = 47.83351
TDC Vol. = Cyl. Head Vol (3.355) + Gasket Vol. (.6601287) + Deck Vol. (.255112) + Piston Dish Vol (.305) = 4.5752407
Gasket Vol. = 3.1416 x Gasket bore (4.100)? x Gasket bore (4.100)? x Compressed gasket thickness (.050)? / 4 = .6601287
Deck Vol. = 3.1416 x Bore (4.030)x Bore (4.030) x Deck Clearence (.020) / 4 = .255112
Piston Volume = (-5) x -.061 = .305
Head Volume = cc's (54) x .061 = 3.294
(converting cc's to ci's by multiply cc's by .061)
All the numbers with parenthesis ( ) are the numbers i put in. The only ones i wasnt sure of was the Gasket Bore and Gasket thickness of the FEL-9966PT. Thats why i put a ? next to them. So if all is true and using the formula given here is what i got:
Swept Vol. (47.83351) + TDC Vol. (4.5752407) / TDC Vol. (4.5752407) = 11.45.1:1 CR!!!
Now im not sure if this is correct because like i said the gasket bore and thickness im not sure yet. I know this might be a little confusing with all the numbers but actually it gives me a challange! (always liked math! )
If you guys think i messed up anywhere let me know or if you KNOW THE FEL-9966PT gasket specs i would like to know so i could try the formula out again. Thanks guys
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
Potent77
Apr 1, 2015 12:45 AM
