Thinking of purchasing 1996 Z28 6 Speed / Needs Work HELP???
Old Feb 13, 2007 | 08:38 AM
curtz28's Avatar
Hi,
So I thought I would ask the experts.
I am thinking of purchasing a 1996 Z28 6 speed for $2500. It has 112K miles, leather interior, keyless, power windows, locks, cd player. It is a hard top coupe (no t-tops unfortuanatly) It does run, but needs the following.
Clutch
Tune-up
Intake Gasket
Water pump
Tires
Possibly Distributor?
Electric fan motor/sensor
Also, when in reverese it pops out of gear if you do not hold it in reverse slot, and it is a bitch to get started, there is something I think with the clutch safety switch? I can get the labor side of the repairs done for about $1000.00
Aside from these things, it does run good.
So my questions are.
1. Is this a good buy?
2. Can I add t-tops aftermarket?
3. Assuming this is a good buy, What parts are the best to use as far as clutch, tires, ect. I am into performance, and would not want to use stock parts.
Thanks, any info is appreciated.
Old Feb 13, 2007 | 08:52 AM
buzz12586's Avatar
I would look around for a t-top 6 speed car. You could find one for around 5-6k which would be cheaper than all the stuff you plan on doing.
Old Feb 13, 2007 | 08:57 AM
Javier97Z28's Avatar
Moderator
That car is going to cost a fortune to get up to speed it looks like. I would not give him more than $1k for it, it just flat out needs too much work.
Having to hold it in reverse is foreshadowing a tranny rebuild in the cards...
Old Feb 13, 2007 | 10:10 AM
2000GTP's Avatar
How is the body of the car? All of the parts and tires you need will easily tally up to close to the 1500-2000 grand mark. And as mentioned above, it sounds like you may need a tranny overall adding additional cost. I would either pass or have him knock the price down another grand.
Old Feb 13, 2007 | 10:17 AM
curtz28's Avatar
96 Z28 6 Speed
Thanks for info. I am going to pass on it. I think for the money I am getting into I am in the relm of spending a little more and getting into a ls car. I guess the only kicker was it is a real nice color blue I havent really seen before. Thanks again for all the info.
Old Feb 13, 2007 | 10:34 AM
2tight's Avatar
Hey if you dont mind please forward me a contact name and number on this car and the location. PM it to me.
Old Feb 14, 2007 | 06:57 AM
METALBEAST's Avatar
I would love to have a hardtop M6 car. Does not look like too much work. I'd give $2K for it.
fpete1992
Dec 11, 2014 03:51 PM
siguy
Nov 27, 2014 10:07 AM
The Seer
Nov 20, 2014 06:32 AM
YellowTransAm350
Mar 2, 2003 03:38 PM
kandied91z
Jul 24, 2002 06:54 AM
