How much for a Header install?
Old Jan 3, 2003 | 08:30 AM
importeater's Avatar
Well how much should I expect to pay to have a gaurage install headers on my 97 Z? I've messed with headers before on vehicles with 6 times the amount of room and forget about it on this thing!! Just would like to get an idea.. Thanks
Old Jan 3, 2003 | 08:54 AM
GREGG 97Z's Avatar
I would say a shop could charge close to $500, possibly more. It's not very complicated but they can be very time consuming. I did my own but I took my time on it, worked on it off and on last winter. It would have been a full weekend project straight through though.
Old Jan 3, 2003 | 09:56 AM
95TA8280's Avatar
8-10 hours around $50-60 an hour, depending on the mechanic....Some shops will discount you a bit if you tell them to have the car for a week or so and just take their time....
Old Jan 3, 2003 | 09:57 AM
jim88iroc305's Avatar
Cool
Any shop with experience in our cars will charge $400 to $600 depending on locality and hourly rate to do a complete install of headers, plugs and wires. This includeds labor and parts (other than the actual headers, plugs and wires) like heat wrap, heat shields and heat ties.
If you're quoted any less be weary.
Good luck
PS
When doing headers it is also a good idea to do plugs and wires at same time if the car has some mileage on it.
Old Jan 3, 2003 | 11:31 AM
EviLBoX's Avatar
I had mine installed for $325 and they didn't do a very good job. I might as well have installed them myself figuring how many times I've pulled the headers and changed the gaskets.
Old Jan 3, 2003 | 11:46 AM
LT1_Man's Avatar
A local guy around here installs them for $250 and he is awesome, but then again he does not run a shop so he doesn't really mark things up. I had mine done in a shop for $250 and it was complete chit. I ended up having to have the guy I mentioned earlier fix all the things that the exhaust shop did wrong.
Old Jul 1, 2003 | 04:10 PM
got_hp?'s Avatar
i would expect most places to charge $300 ish
a shop down in ftlauderdale i know of specializes in fbodies and they do header installs for like $150..........guess they have it down to a science.
Old Jul 1, 2003 | 04:33 PM
Cmr0z28's Avatar
i know what shop you're talking about......theyre running a special and will do a header install for $129.99
Old Jul 1, 2003 | 04:38 PM
BO94ZA4's Avatar
I worked at Midas for 5 years and the lt1 is the most easy header install there is in my opinion. I usually charged around 250-300.
Old Jul 1, 2003 | 04:47 PM
BradZ28's Avatar
Find fellow board member to help and pay them 200 or so to do it right....much cheaper!
Old Jul 1, 2003 | 05:12 PM
gb95zconv's Avatar
Bingo....if you have headers you will have to replace the gaskets from time to time so you may as well get use to working with them. Just get the right tools. Thin wall swivel sockets to bolt them to the heads and air wrenches to bolt up the collectors and exhaust. Use the $400- $600 to buy tools with
Old Jul 8, 2003 | 07:32 AM
Coolformula's Avatar
I had mine done for 75.00 local place, always does real good work, I kinda felt bad it took him 2 days so I gave him 95.00. That price included welding up my y-pipe to my offroadpipe/borla. So I was very happy.
Old Dec 2, 2019 | 10:46 PM
John James's Avatar
Re: How much for a Header install?
Any chance you’re still around and can name the shop in ft Lauderdale, in case they still do headers for fbody?
Old Aug 29, 2022 | 09:01 PM
Nwilly28's Avatar
Where at???
Old Aug 30, 2022 | 06:30 PM
“got_hp” hasn’t signed into this site since 2010.
If you click on his screen name, there's an option to send an email. That might work.
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
