How much for a Header install?
Well how much should I expect to pay to have a gaurage install headers on my 97 Z? I've messed with headers before on vehicles with 6 times the amount of room and forget about it on this thing!!
Just would like to get an idea.. Thanks
I would say a shop could charge close to $500, possibly more. It's not very complicated but they can be very time consuming. I did my own but I took my time on it, worked on it off and on last winter. It would have been a full weekend project straight through though.
Any shop with experience in our cars will charge $400 to $600 depending on locality and hourly rate to do a complete install of headers, plugs and wires. This includeds labor and parts (other than the actual headers, plugs and wires) like heat wrap, heat shields and heat ties.
If you're quoted any less be weary.
Good luck
PS
When doing headers it is also a good idea to do plugs and wires at same time if the car has some mileage on it.
Good luck
PS
A local guy around here installs them for $250 and he is awesome, but then again he does not run a shop so he doesn't really mark things up. I had mine done in a shop for $250 and it was complete chit. I ended up having to have the guy I mentioned earlier fix all the things that the exhaust shop did wrong.
Originally posted by EviLBoX
I might as well have installed them myself figuring how many times I've pulled the headers and changed the gaskets.
I had mine done for 75.00 local place, always does real good work, I kinda felt bad it took him 2 days so I gave him 95.00. That price included welding up my y-pipe to my offroadpipe/borla. So I was very happy.
