how much did it cost you to rebuild your shortblock ?
Old Jul 19, 2010 | 09:54 PM
  #31
MachinistOne's Avatar
Originally Posted by brucer
my bore gage is a mitutoyo and ive been using it for around 22years... i'm not an automotive machinist, i'm a lowlife tool&die maker and gearhead, so i think i can use and read a bore gage, and O.D. and I.D. mics just fine... i also dbl checked with 3 strips of plasti-gage. when you do that it would show up a mismatch...
explain to me then, if your caps are sitting flat in the register, and on the flat surfaces of the maincaps, and tight in the registers, if you oil the surfaces where the torque is applied wheres the cap going to go?
now in this guys case looks like the maincaps were loose in the registers a little (not the tap fit) when they were torqued which caused them to twist with the applied torque..
Well, you have a good gauge, and can read it
Regardless, it's not a ploy to make some money off the line hone job - every single time I install main studs or girdles I can measure the distortion in the housing bore. If you take the time to measure it, you can even see changes in the bore geometry by varying the applied torque by even 5 lbs up or down. You can't just measure the vertical and horizontal, you need to measure all the way around the bore, and to a certain extent that mitutoyo gauge is dampening your readings as the sunnen gauges that we have I have compared back to back with the mitutoyo and they are more sensitive to higher order bore geometry distortions due to their different centralizer design. Fact of the matter is that you are still only measuring the distance between two points, and I wish had my books on the computer(pictures) but there's multitudes of drastic out of round and distorted bore scenarios that can be had while your stick gauge still shows an in-spec housing bore. And on top of that it will show you nothing of bore to bore alignment through each saddle of the main line.
It is just like cylinder bores, the reason for plate honing with the fasteners that will be used at the applied torque that will be used, all these factors change the bore geometry. Ask any machinist who does honing, put that plate on or studs in the mains and you can literally feel the stones load and un-load as they cut the distorted housing bore into a round shape.
I'm not going to get into a competency argument, I will simply say that you would be hard pressed to find any engine builder that would say it's ok to install main studs and not follow it with a line hone.
And I have had several blocks brought in over the years with garage assembly jobs by people who thought they could just throw studs in and ended up wiping all their main bearings and trashing thousands of dollars in components just to save $350.
LT14LIFE
Nov 15, 2015 06:22 PM
Z Power
Sep 19, 2015 11:19 PM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
