How much compression on pump gas?
Old Feb 29, 2004 | 06:53 PM
Got-LT1's Avatar
How much of a CR can you run an LT1 with 93 octine gas?
Old Feb 29, 2004 | 07:02 PM
Ai's Avatar
Ai
What static compression you can get away with will depend entirely on the combination of parts you're going to run & how you're going to run them. A search in adv. tech on dynamic compression ratio can help explain that a bit...
That said, I think being safe & staying around 11-11.25:1 isn't a bad idea for most setups that are going to be daily driven on pump gas. About the most I've had customers run with an average HR camshaft (~230deg int duration) has been just under 12:1 & they haven't reported any issues thus far, but I'd always prefer to be safe as opposed to sorry when depending on pump fuel.
Magenta_Hearts
Mar 22, 2015 03:36 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
simple
Aug 11, 2002 11:56 AM
dmaastr
9
Jul 1, 2002 02:22 PM
