how much for cam install
Old Sep 4, 2003 | 12:34 AM
mickeyiz28's Avatar
just on average what would i expect to pay for a cam switch, some 1.6rrs and some new pushrods?
Old Sep 4, 2003 | 01:07 AM
ROADRAGE's Avatar
Not gonna be cheap. Keep in mind, you should probably change the timing chain and maybe the opti while you have it apart. LT1 timing chains arent cheap, so you may want to consider going with a standard double roller timing chain and an electric water pump. So basically, one million dollars, give or take
Do it yourself. cam is pretty easy, if you arent doing heads to
Old Sep 4, 2003 | 01:25 AM
scoobysnax83's Avatar
I would estimate that if you do it yourself. It would be roughly...
Cam $250
Timing gears and chain $150
new springs (depends on cam) $200
roller rockers $200
gaskets $80
$880 +-
Now if you want a mechanic to do it for you... Just tack on a grand and you're about right. But like said above, its not that hard to do. I'm in the process right now. Shoebox's websit is a god send for what you are look for. Good Luck, its all worth it in the end
Old Sep 4, 2003 | 03:43 AM
Rich_z28's Avatar
Don't forget tuning. Figure about 100-150 for mail order tuning and around 300 for a dynotune.
Old Sep 4, 2003 | 06:43 AM
Good point. If you go with a standard cam, there's really no necessity to dyno tune. However, a dyno tune would be the best way to do it. Another factor depending on how big or aggressive of a cam you decide on is upgrading fuel system components (injectors, fuel pump). These upgrades should be handled before you send your computer off for a reprogram, or you'll be doing it twice.
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
