How many miles are on your LT1 ?
Old Jun 26, 2005 | 07:53 PM
  #31
pvollman's Avatar
Re: How many miles are on your LT1 ?
121K on mine...148K on the wife's
Old Jun 26, 2005 | 08:00 PM
  #32
CamaroBoy96Z28's Avatar
94,404
Replaced distributor and waterpump at 82k 3 years ago about 2 months after I bought it and nothing ever since.
Old Jun 26, 2005 | 08:17 PM
  #33
Camaro350z28's Avatar
176k and opti needs replaced. Other than that it runs strong. 13.8 with a 2.3 60' i believe is what it was.
Old Jun 26, 2005 | 08:23 PM
  #34
2cub49's Avatar
I drove my car hard up to 110,000 miles from the 28,000 it had when I got it in 2000. I went through a few trannys and 2 optis and a water pump. Changed the valve seals at 100,000 miles as it would blow a little blue smoke on startup.Now with the S/C it has so much torque with the 9 lb pulley I don't beat on it so much and after 10,000 S/C miles it has no blowby even at 5 or 6 psi which is what I practically see in the mid rpms.
Old Jun 26, 2005 | 08:53 PM
  #35
SP2340's Avatar
134,000 only semi major problem was the intake oil leak and now my water pump drive shaft is stripped so I'll probably get get an electic one.
Old Jun 26, 2005 | 09:11 PM
  #36
93black-ta's Avatar
mine died around 210,000
Old Jun 26, 2005 | 09:20 PM
  #37
tardy007's Avatar
33,000. Not driven much
Old Jun 26, 2005 | 09:35 PM
  #38
slowpoke96z28's Avatar
205,566
Old Jun 26, 2005 | 09:41 PM
  #39
gt_biker13's Avatar
111,000 still runs strong, previous owner was pretty good on it.
Old Jun 27, 2005 | 01:10 AM
  #40
carolinacasper's Avatar
150K...Replaced ECU three times and the Opti once. Fixed A/C twice, changed a lot of headlights 1993 LT1 burns/loses 1/2 quart every oil change.
Old Jun 27, 2005 | 01:30 AM
  #41
Black1995Z's Avatar
Lost oil pressure @ 146k.... car was still running great on n2o. Keep your eye on your oil pressure! It wasnt a bad motor just a bad pump.
Old Jun 27, 2005 | 02:33 AM
  #42
FormulaW66's Avatar
156k on mine never been rebuilt No NOS ever
water pump went out around 80k (extended warrenty covered it)
still original opti
got the stealership to put on a aluminium drive shaft under warrenty
had some isues with the stock rear end wanting to break teath off every 6 months but Moser 12 bolt and BMR adjustable control arms, adjustable torque arm and panhard rod fixed all that. (and a good rear end shop to fix the moser isues)
oil change every 3k and keeping up with general matanance the car and engine has been very reliable. its my only car so its a daily driver.
but just like any car if you dont take care of it and run the hell out of it, it will break eventualy.
Old Jun 27, 2005 | 06:24 PM
  #43
Josh 94Z's Avatar
220k on mine. original opti. Head gasket just blew, so I'm going to re-build.
Old Jun 27, 2005 | 08:49 PM
  #44
69gto96z's Avatar
94,000. Just replaced the radiator, water temp sensor, and all 02's.
Old Jun 27, 2005 | 09:46 PM
  #45
baddboy1705's Avatar
Post Re: How many miles are on your LT1 ?
just like everyone else... new opti, plugs wires, coolent temp sensor, outter tie-rod ends, rear driveshaft seal, 173,xxx but still running strong...
Thats a hell of a deal on that car if you ask me, but like everyone else said make sure you have it checked out by someone certified, or that knows what their doing so you dont screw yourself into a lemon....not that GM ever made any lemons... right?!? haha good luck with the buy!
