How many ground point on the engine?
Old May 14, 2007 | 07:22 AM
always faster's Avatar
Im still searching for my problem after my new motor install(cranking but no start) i ve check my ground to see if they are good or if there is a missing one.
How many grounds point does the engine have:
-Strap from the driver head stud to the body
-2 wire from that are in the same looms has the icm/coil/maf to the driver head stud
-1 wire from the starter loom that goes to the pass side of the block
Am i missing one?
Old May 14, 2007 | 07:57 AM
What about the main battery cable ground to the block?
Old May 14, 2007 | 08:01 AM
Originally Posted by shoebox
Yep your right i ve forgot this one in my list but i didnt forget it on my install.
Old May 14, 2007 | 09:35 AM
I didn't think it would be cranking without that one. You probably have an issue with something else.
Old May 14, 2007 | 09:48 AM
Yeah probably
Im just trying to be methodical because 3 weeks later im still unable to start it so know im taking each point at a time and verify it so:
Ground: OK
Old May 14, 2007 | 10:58 AM
afr lt1's Avatar
sorry, but....do you have gas in the tank?
did you recheck your plug wires?
or maybe the position of the opti when you re-attached it. you know, the circle that spins on the back.
Old May 14, 2007 | 10:13 PM
I dont know how many time i ve been ask for ths question...My tank is full of gas.
My plug wire are good and i even try 2 set.
The pin drive opti is well set but i ve order a new one to see if this is the problem.
Old May 14, 2007 | 10:41 PM
SnakeOiler's Avatar
Is the coil good?
injector fuse good?
Old May 15, 2007 | 07:11 AM
Originally Posted by SnakeOiler
Is the coil good?
injector fuse good?
Yep i ve tried with the stocker, a msd blaster and with a Delteq
Fuse are good too.
DirtyDaveW
Dec 1, 2016 05:37 PM
Sergio
Jan 27, 2016 04:27 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
