How long to wait after sea foam to change the oil?
Old Aug 17, 2006 | 05:17 PM
  #16
1racerdude's Avatar
Re: How long to wait after sea foam to change the oil?
Your first mistake was using it at all.
Old Aug 19, 2006 | 02:08 AM
  #17
Josh'95Z28conv's Avatar
Seafoam is great stuff. I dont recomend running it in your crankcase though. It works wonders in the fuel system, and does well breaking up carbon when pouring it in the intake.
Old Aug 19, 2006 | 03:38 AM
  #18
1racerdude's Avatar
Ya are burning UNLEAD,unless ya are using the hell out of oil,where is the carbon gonna come from?
Back in the day ya would have to chisle the tops of the pistons to get it off. What gets on there today ya can wipe off with a rag.
WHERE is the carbon?
Old Aug 19, 2006 | 10:02 AM
  #19
I have to decarbon small engines all the time. When they run rich, or run a lot without much load. they build up carbon in the combustion chambers. Its bad enough that you have to scrape it off in chunks sometimes. But if something like seafoam is used on a regular basis, you wont have that much build up. Sometimes it is from burning oil though.
Old Aug 19, 2006 | 10:25 AM
  #20
1racerdude's Avatar
I have not seen a SBC or any other engine with "carbon" in it for the last 15 years so I don't know where yours is coming from...
Old Aug 19, 2006 | 10:44 AM
  #21
96capricemgr's Avatar
You guys act like Seafoam is something more than what it is. ALL it is is naptha(paint thinner) alcohol, some light oil and dye.
Naptha is a great hydrocarbon solvent and could do some cleaning if there is something to clean.
Far as running it through the intake a squirt bottle with water could do the same cleaning the mist getting sucked into the engine is like pressure washing things just have to be careful not to hydrolock.
Far as running it in the oil, look back at what I said is in that stuff, would you intentianally put paint thinner in your oil?? Berrymann's B12 Chemtool smells EXAXCTLY like laquer thinner. Moral of the story is most fuel system cleaners are NOTHING SPECIAL just common solvents with often marginal at best results.
There are some good products out there but they are harder to get ahold of and put more focus on quality over marketting so you have never heard of them.
DirtyDaveW
Dec 1, 2016 05:37 PM
marineengineer
Feb 9, 2015 03:59 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
