how to leen out lt1 ?
Old Oct 17, 2005 | 07:34 PM
Bandit95LT1's Avatar
how do i leen out my relatively stock lt1? i did a search and i read the an adjustable fuel pressure regulator will just cause the injectors to pulse faster so what do i need to do?
Old Oct 17, 2005 | 07:49 PM
OBE1 95Z28's Avatar
Re: how to leen out lt1 ?
If your LT1 is relatively stock, the stock program should manage your air/fuel ratio if your car is properly tuned. As the O2 sensors age, they get coated and cause the engine to run more rich. You might start with new Delco O2 sensors.
Old Oct 17, 2005 | 07:58 PM
not bad idea i do have 111000 on the stock ones if i sent the computer to like mad z28 you think it would help cuzz i am taking the cat off and i dont want it to back fire to bad cuz evan now with a cat on itit back fire at bout 6 grand
Old Oct 17, 2005 | 08:15 PM
OBE1 95Z28's Avatar
If it's stock, no need for programming. Tune up including new Delco O2 sensors.
Old Oct 17, 2005 | 10:39 PM
Why "no need for programming" if its stock? Simply leaning out the PE mode target A/F ratio tables is good for about 15HP on a stock engine. The stock tuning typically targets about 11.7:1 on WOT, compared to the 12.8-13.2:1 that most people find produces max power/torque.
Now, if its definitely running rich at part throttle/part load conditions, you may ALSO have a problem with the O2 sensors, a leak in the exhaust before the O2 sensors or misfires. Fix that problem first, then alter the PE tables yourself (LT1_Edit or TunerCat), or have one of the mail-order tuners that are recommended here do it for you.
Old Oct 18, 2005 | 09:43 AM
OBE1 95Z28's Avatar
Fred,
I was answering this thread regarding tuning to address his exhaust backfiring issue with a stock setup; HP gains are always good too
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
