how to install timing gear on crankshaft
Old Jul 10, 2005 | 08:30 AM
93redlt1's Avatar
Can i just use a pipe and tap it on or will this damage the main and rod bearings.
Old Jul 10, 2005 | 08:33 AM
Re: how to install timing gear on crankshaft
That's how you do it. Just don't go crazy. Tap it until it is flush with the crank.
Old Jul 10, 2005 | 11:17 AM
Jameslt1TA's Avatar
If your not sure of something...try shoebox's pages they are great.
Old Jul 10, 2005 | 01:39 PM
toegead93's Avatar
I don't know if your asking because your just unfamiliar with installing it or if you're having trouble, but keep in mind that unless you've upgraded to a vented opti you cannot use a double roller timing chain set. I had a lot of issues a couple of weeks ago tracking down a timing chain that would work on my 93 Z. I got 4 different part numbers from Crane & Summit, I bought one and it didn't work. Everyone was trying to sell me chains for 95+ LT-1's.
Old Jul 10, 2005 | 02:22 PM
93redlt1's Avatar
oh thanks for all the help guys. i did upgrade to the vented but was just unsure if i was allowed to hit it on.
Old Jul 10, 2005 | 02:23 PM
1racerdude's Avatar
Put it in the oven@ 300* for a couple of hours,have your pipe and beater handy and haul *** to the car and put it on.It will probably go on by hand.
Old Jul 10, 2005 | 07:10 PM
ZMAN Z28's Avatar
Couldn't you just heat it with a torch? I don't know, just asking?
Z
Old Jul 10, 2005 | 08:04 PM
1racerdude's Avatar
Z
Yea IF ya have done it a BUNCH.Ya don't want to over heat it it will take the heat treat out of it.Ya need heat sticks and ya need to get it the same temp all over.(not recommended)
The oven is a controlled environment.
Old Jul 11, 2005 | 09:45 AM
Compstall's Avatar
I put mine in a pan and heated it up that way. Grabbed it with a rag, ran into the garage and it slid on like butter.
Old Aug 4, 2008 | 09:40 AM
GMH94Z28's Avatar
I know this is an old thread but how long did you heat in in the oven and at what temp? Thanks
Old Aug 4, 2008 | 01:47 PM
Compstall's Avatar
Make it hot enough that if you drip water on it, it will sizzle.
Old Aug 4, 2008 | 01:56 PM
JoeliusZ28's Avatar
well ill put my reputation on the line here and say that I beat the living hell out of mine (SHOULDNT HAVE) when it wouldnt go on and I havent spun a bearing yet like I thought i was going to.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Noenav
Dec 6, 2014 07:35 PM
1LEThumper
Jul 14, 2003 12:45 PM
