how good is the stock balancer?
Old Jun 26, 2008 | 05:16 PM
blue 79 Z/28's Avatar
building up an AI200cc combo on a 355. full bolt ons, stock crank, arp bolts etc. forged 6" rods mahle pistons etc. looking for the 440rwhp area. can i run the stock hub and balancer and not worry about the bottom end? or is it worth it to spend the big bucks and get an ATI? i only plan on 6700rpm max for this combo, street car mostly, some track. just wondering how good the stock one is with a good balance job in the rotating assy.
Old Jun 26, 2008 | 05:37 PM
bombebomb's Avatar
Im also very curious on this same nearly exact question except id have nitrous. So ill be watching
Old Jun 26, 2008 | 05:54 PM
Its not a balancer, its a harmonic damper. I doubt GM took anything above 6,000 rpm into consideration for the design. The ATI will reflect a design for higher RPM. It will also be SFI certified, and dated, which means it meet the requirements for NHRA (required under 11.00 seconds).
Whether you have nitrous is not a factor.
Old Jun 26, 2008 | 05:57 PM
bombebomb's Avatar
Eek, time to drop another $300~ alwell gotta pay to play.
Old Jun 26, 2008 | 05:59 PM
The ATI is closer to $400.
Old Jun 26, 2008 | 06:13 PM
i know its a damper, i dont know why i called it a balancer, just a bad habit term lol while those are all pluses like SFI and higher rpm etc. i was just wondering what i could get away with without dropping the coin. i mean will i have a busted crank and beat up bearings or will it survive? anyone running it successfully at that power and rpm level? or is it w waste of time?
bombebomb's Avatar
Ironic, I edited my post before finalizing it, it did say $400, but I changed it just in case, turns out I was right the first time.
Old Jun 26, 2008 | 06:14 PM
yea since im in canada its really pricey. listed as 355 usd on summit though, its about 390 local
Old Jun 27, 2008 | 11:50 AM
stockblock's Avatar
i have a buddy running one up to 7000+ rpms running low low tens
the rotating assembly was balanced to within 3 grams though but it has lasted 2 seasons with that kind of abuse
Old Jun 27, 2008 | 12:20 PM
k, thats what i needed to know. ill upgrade when i need to. saves money to get this thing done!
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
