How to get into 12's
Old Aug 8, 2003 | 02:30 PM
  #16
Cmr0z28's Avatar
rofl
Old Aug 8, 2003 | 11:39 PM
  #17
mebanditws6's Avatar
Originally posted by No4nRice
After reading the install, I decided I'm not gunna mess with a torque converter until I build my 383. I was wondering if this combo would get me in the 12's, and if so, about where?
Hooker LT Headers
Catback Exhaust
Lingenfelter CAI
B+M Shift Plus Kit
LT4 Hot Cam
3.73 Gears
75 Shot n2o
Drag Radials
If you're gonna go to the trouble of pulling everything down to the shortblock, why not just save 500 bucks or so and get a good port job on your stock heads then go for a bigger cam, say maybe something about the size of the 306 or a little bigger. That way when you do build your 383, you can use the ported heads with the stroker.
I'm not sure why you want to tear into the motor for just a cam swap and turn around and build a 383? I'd just stick with bolt ons, gears, and nittos before tearing into the motor. If you do every bolt on with LT's, you should see high 12's on a cold day. just a though
Jason
