How to get block drain plugs out, having troubles!
I am pulling out the block drain plugs, and I am having a problem.
How do I get to the plugs, what size does the plug take and what size does the knock sensor take.
And what combo of tools did you use to get to them each?
Thanks,
James
Thanks,
James
Re: How to get block drain plugs out, having troubles!
Passenger side is easy, just pull out the knock sensor. I couldnt get the drivers side out with the motor in the car. When I pulled my motor I put a drain **** in so I could drain that side if needed.
Magenta_Hearts
Mar 29, 2017 08:54 PM
eanhl2004
Apr 4, 2015 12:01 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Sandersen511
Jan 13, 2015 03:49 PM
