how far should the cam dowel pin protrude from th e cam gear??
I am in the middle of doing a complete rebuild and I am at the point of putting on the opti and I am doing a 94 - 95 opti conversion. I installed a comp cam 07-306-8 cam shaft with a LT4 extreme duty timing set.
How far should the dowel pin protrude from the cam timing gear???
With the timing set installed my pinprotrudes out maybe .050, and yes .050 not .50. If I am correct shouldn't the pin drive the opti and shouldn't I have more pin to fit into the notch of the opti gear??
It's a comp cam 306 cam, shouldn't I not have to worry about this?? I am going to be soo upset if I have to take it all apart.
John
John
My total stock pin length was ~.650 and protrusion from the stock cam gear was ~.410.
.050 sounds awfully short.
It's got to be able to get some depth into the opti drive for it to work. My .410 measurement is not from an LT4 gear, but I think it would be relatively the same.
so what do I do now?? Where can I get a longer dowel pin??
so for 95 and up it shouldn't look like this
http://www.cis.udel.edu/~davis/z28/b...ll/camgear.jpg
Looking at that picture, it looks like a '94 cam. The hole in the center seems too small for a '95 opti to fit. Compare with this picture.
http://para.noid.org/~muttvette/opti.html
Originally posted by john-e-boy
Is this what it is supposed to look like
http://www.streetillusionsracing.com...amsprocket.jpg
The link that you say looks like yours is not gonna cut it.
Just got off the phone with comp cams, I told him what has happened and what my engine was. He tells me, now get this...
"you must have got one with a short pin"
I didn't know they made the cc 306 with a short pin??
I guess it is turning out ok, He says he will send me a new pin at no charge and also told me how to remove the old pin and install the new one. I just hate having to remove the cam and install it all over again. Now I just have to play the waiting game.
I guess it is my fault for not checking the lenght of the pin before I installed the cam, I just took for granted that the cc 306 came with only one size pin.
Thanks for all the help
John
John
why dont you just measure your stock cam and use that length
Curious as to what they told you about removing the pin as it is a common question around here.
Jul 4, 2005 05:00 PM
