What bushings to replace with shock and springs
Old Jan 7, 2004 | 02:00 AM
scoobysnax83's Avatar
I'm about to do shocks and springs. What bushings should I replace while down there. Mind you this is a 165,000 miles suspension....
Also, it is just being replaced with factory oem shocks and springs.
Thanks for the help
Old Jan 7, 2004 | 08:44 AM
thermwood1's Avatar
It would probably be a good idea to replace all of the factory rubber bushings in both the upper and lower control arms. Also, i would do upper and lower balljoints and both tie rod ends. If you are going to have it apart, now is the best time for everything.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dbrockma
Feb 16, 2015 02:56 PM
ModdedNerd
Feb 5, 2015 04:37 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
