How does the PCM sense the AIR?
Old Jul 29, 2003 | 09:40 AM
TheHeadFL's Avatar
This is a question for myself, and for my friend with a 95 T/A.
I know that removing AIR on an OBD2 will set a SES. But what does it use to sense this? If the pump were hooked up and blowing air out into nowhere, would it know that it was not functioning?
Also, will removing AIR on my friend's OBD1 set a SES?
Old Jul 29, 2003 | 10:30 AM
The 93-95's will not set an SES or a code for the missing AIR pump, as long as you have a good fuse in the circuit. The 96/97's have flow detector in each branch of the air tubes, I believe.
Old Jul 29, 2003 | 10:39 AM
JWA95TA's Avatar
yup obd1 doesnt set a light on the AIR. Even if it is not even plugged up. THe EGR will set a code though.
Jason
Old Jul 29, 2003 | 11:01 AM
thewinner's Avatar
its nothing to do with the flow in the tubes, since there isnt anything flowing in closed loop.
im thinking the pcm has to see a closed circuit for it not to set a SES, and when you open the circuit the light goes off.
Old Jul 29, 2003 | 11:05 AM
PatriotTA's Avatar
That sounds right. For OBD2, either the PCM senses the closed circuit, or it senses the resistance of the air pump. Either way, it doesn't matter if its OBD1. I removed my air pump and let the connector hang and it hasn't set a code. I put a resistor in the connector for my EGR, though (which hasn't set a code BTW)
Old Jul 29, 2003 | 11:53 AM
TheHeadFL's Avatar
So if I leave the AIR pump plugged in on my 97, but not connected to the exhaust manifolds at all, wouldn't that keep the circuit closed and functioning? It could just pump air out into nothing.
I think Fred must be right about flow sensors because I think it would still set a SES somehow.
Mainly I want to get rid of all that stupid hard metal tubing that runs all over everywhere.
Old Jul 29, 2003 | 01:43 PM
PatriotTA's Avatar
I think you could get rid everything (including the pump itself) and just put in a resistor. I used a 2.2k ohm resistor in my EGR harness and haven't thrown a code. I'm not sure though, cuase I have OBD1. Hopefully someone else with OBD2 will chime in, but it makes sense to me.
Old Jul 29, 2003 | 05:37 PM
revtime's Avatar
I removed the AIR and the EGR on my 94 and it has not set a code.
I left the fuse in for the AIR and I just pulled all the crap for the EGR and plugged the manifold vacuum port. No codes.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
jasonduaine
Mar 7, 2015 09:44 AM
95chwagon
Jan 13, 2015 09:19 PM
