How does a adjustable fuel press regulator help an LT1
Old Apr 20, 2003 | 11:44 AM
Alan566's Avatar
I thought the pcm set the pressure at what is needed. Please explane it for me. Thanks Alan
Old Apr 20, 2003 | 12:21 PM
norcalstreet's Avatar
It only helps on the '93 model. In other years the PCM will adjust the fuel injectors to compensate for any fuel pressure changes. To be accurate the PCM doesn't monitor fuel pressure but will notice an increase in richness through the O2 sensors and will adjust the fuel injector accordingly. You will feel a good gain of about 10HP at first but after the PCM takes its readings that gain will disappear. This isn't the case with '93 models as they don't contain this ability.
DirtyDaveW
Dec 1, 2016 05:37 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
dansam
Jul 20, 2002 01:10 PM
