Can I even use the LT4 know modual on my 93?? i have heard that it helps a lil bit if you have put on headers or something that might cause some false knock.
The computer is different on a 1993 and does not use the replaceable KM. If you have false knock, you can try to desensitize the sensor. A search should find you some info.
