How do you reset the pcm or ecm?
Old Jul 13, 2003 | 01:04 PM
speed76demon's Avatar
just like post says
Old Jul 13, 2003 | 01:19 PM
Rich_z28's Avatar
Pull one of the the battery cables off.
Old Jul 13, 2003 | 01:20 PM
94ZVert's Avatar
Unplug the Negative cable off the battery.
Old Jul 13, 2003 | 01:22 PM
1997rblckSS's Avatar
pull the pcm fuse out for about 15 minutes, then put it back in..
Old Jul 13, 2003 | 01:35 PM
94ZVert's Avatar
I don't think that pulling the fuse will reset any codes though. But then again, I don't know if that's what he actually needs from reading his post.
Old Jul 13, 2003 | 02:25 PM
roadtrip120's Avatar
Pull both fuses from the fuse box in side the car for 1 min. this will work not 15 min.
Old Jul 13, 2003 | 02:29 PM
Pull the fuse marked "PCM BAT" in the panel on the drivers end of the dash in your 94, for 30 seconds. This will clear the volatile portion of memory, including the long term fuel corrections, trouble codes, and learned idle position.
If you decide to pull the battery cable, make sure you know your radio security code.
Old Jul 13, 2003 | 03:07 PM
StephenF04's Avatar
EASIEST way IMHO is just to unhook the negative side of the battery
Old Jul 13, 2003 | 03:11 PM
Easier than pulling a fuse?
Old Jul 13, 2003 | 05:43 PM
So how long will it take my pcm to learn my new mods??
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
frankrizz
Sep 23, 2015 04:21 PM
