how do i jump the starter???
Old May 18, 2006 | 11:51 AM
  #16
SweetZRag's Avatar
Re: how do i jump the starter???
Originally Posted by jamilz28
my car wont start and someone told me if my starter is broken and i jump it and it works then my starter is bad
I think this person meant that if you jump the starter and it works, the problem is not your starter. Or he meant that if you "bump" start it (manual transmission necessary) then it could be the starter.
To remove the Y pipe:
--Disconnect electrical connectors for the O2 sensors located in the Y pipe.
--Remove 3 nuts from each flange (both sides) where the Y pipe connects to each exhaust manifold. TIP: Soak the nuts in penetrating oil like PB Blaster first.
--Remove the bolts and nuts (2 pair) for the mounting bracket at the back of the catalytic converter.
--Disconnect the two pairs of nuts and bolts from the flange at the output side of the catalytic converter.
--Remove Y pipe with catalytic converter.
Hope this helps!
Jeff
Old May 18, 2006 | 12:00 PM
  #17
1SlowFormula's Avatar
Jeff,
I could be wrong but I didn't think the 94 and 95's were that different and I got my starter out witout removing my Y-pipe, is it mandatory for yours?
Old May 18, 2006 | 02:26 PM
  #18
SweetZRag's Avatar
Its been a while so I am not sure now. I know everything is easier on that side with it removed and with air tools, I don't think twice about removing the Y pipe.
I was just kinda answering his question about how to get it out. Wasn't really thinking about if it had to come out. I seem to recall it was necessary. Old age must be kiccking in!
Jeff
Old May 18, 2006 | 04:25 PM
  #19
jamilz28's Avatar
Originally Posted by 1SlowFormula
^^^ no need to
sweet i will look at it 1 more time cuz i thought that i would have to take it off
Old Sep 12, 2023 | 12:45 AM
  #20
Raven111's Avatar
Jeff,
The 95 is very different from all the Camaros..I'm learning this **** the hard way. I love camaro's but what the hell where they thinking with the 95 that's the year Ive got n I seriously wanna drive my car period but mainly into a brick wall!!
Old Sep 12, 2023 | 07:10 AM
  #21
Not all that different.
From shoebox, a table of year-to-year differences:
http://shbox.com/1/4th_gen_f-body_ye...onversions.pdf
Formula Steve
Sep 19, 2023 08:31 AM
PopoFormula
Oct 12, 2015 04:19 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
tdigger9899
Sep 7, 2015 10:56 AM
