How do I install the Cam trigger?
Old May 8, 2007 | 09:59 AM
Rodrigues's Avatar
I have an LT1 with an SBC intake and I've bought the 8.1L cam trigger. The cam trigger has a solid mounting point (doesn't swivel like a normal distributor). I'm going to be using this with a BS3 computer and a coil on plug setup. Heres a pic of someone else using a similar setup and I'm curious how they dialed in the cam sync. I also have a 24 tooth crank trigger that I will be using to emulate the LS1 trigger so I can use the LS1 style BS3. I believe the BS3 needs a certain amount of advance before TDC (I can figure that out) but how do I set that advance? Theres a few screws on top of the sensor that goes down the distributor hole and I'm wondering if I need to take that out to rotate the sensor's swing arm while its secured in the distributor hole. Any ideas on how to do this?
Old May 8, 2007 | 10:04 PM
Rodrigues's Avatar
No one eh?
Old May 10, 2007 | 12:48 PM
Rodrigues's Avatar
Is this an advanced tech question??
Old May 11, 2007 | 06:31 PM
ltlhomer's Avatar
You worry too much Pat.
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Jul 23, 2002 09:24 PM
