How do i fix this alternator belt squeaking?
Old Mar 4, 2005 | 02:52 PM
tybz28's Avatar
My alternator belt or the alternator itself is squeaking. My car is loud and i can hear it over the engine at idle. My uncle works at the chevy place and he put some grease looking stuff on the inside of the belt and that seemed to help for a while. How do i fix this? Thanks.
Old Mar 4, 2005 | 02:55 PM
OBE1 95Z28's Avatar
Re: How do i fix this alternator belt squeaking?
Replace the belt (about $25). Belt dressings will only temporarily eliminate the noise.
Old Mar 4, 2005 | 03:59 PM
Kataklysm's Avatar
Well you need to find out if its the belt or the pulley. If its the pulley replacing the belt won't do anything for it. Stick your head next to the alternator pulley when its running and listen to it.
Old Mar 4, 2005 | 07:13 PM
396D1SS's Avatar
usually its the belt tensioner pully that causes the squeeks in the lt1's. Ive also seen spun harmonic balencers squeek to
Old Mar 4, 2005 | 10:21 PM
OBE1 95Z28's Avatar
According to the original post, the noise "got better" when a "grease" was applied, that's why I don't suspect the pulleys. It's a common problem for the belts to cause a squeal. Pick up a Goodyear Gatorback belt. It's a better design that has cross slits to allow the belt to run over tight radius turns (like the alternator pulley) without generating as much heat to accelerate belt fatigue.
Old Mar 5, 2005 | 12:29 PM
transamdude95's Avatar
Just replace the belt. Belt dressing can make it worse and make your engine bay look like crap.
TheGreenZ28
Oct 4, 2020 11:29 AM
blkWidow
Apr 20, 2015 09:27 AM
moparman
Feb 11, 2015 08:29 AM
Snoman73
Nov 17, 2014 07:22 PM
MislMan
Jul 19, 2002 11:41 AM
